Any problem using a 6L gasket on stock bore?
Old 02-16-2005, 10:32 AM
Camaro ChriSS's Avatar
Default Any problem using a 6L gasket on stock bore?
Are there any problems with using 6L head gaskets on a stock 3.9 bore with AFR205 heads?
They came with my set up for installation, so I just want to make sure that the gaskets will be fine before starting. Double checking as it were.
