Valvespring recommendations for my setup?
Old 02-17-2005, 05:17 PM
GTPprix's Avatar
Default Valvespring recommendations for my setup?
OK Guys and Gals, the time has come to upgrade the valvesprings on my Goat Here is my combination thus far:
Procharger P1SC-1 at 7 PSI currently switching over to 8-9 PSI
Stock Cam/Heads and all other engine internals.
I'd like to be able to run the motor to about 6500 (or 6700 if thats even possible (read SAFE) on the stock bottom end?) With these goals in mind would you go with:
A. the CC 105 lbs spring (IE 26915)
or
B. the CC 130 lbs spring (IE 26918)
Both would be using the titanium retainers, not that it makes a difference but I figured I'd throw that in there. Input is ALWAYS appreciated, thanks!
Old 02-17-2005, 07:16 PM
smask04C5's Avatar
Remember that as boost increases, spring pressure is reduced at the valve. If you have a 2.25 inch intake, there is roughly 4 sq. in. of backside valve area. If you run 9# boost, you reduce spring pressure on that valve by 4 x 9= 36# of reduced spring pressure, 69# won't control a 2.25 inch valve. Granted, 2.00 LS1 intakes are not 2.25, but you get the idea? I would go with 130's.
Old 02-18-2005, 12:10 AM
01_SuperSlow's Avatar
Out of those two, I suggest the 918's.
Old 02-18-2005, 08:39 AM
PREDATOR-Z's Avatar
Yeap 918's
or cheaper yet 02/03+ LS6 springs.
Old 02-18-2005, 10:38 AM
GTPprix's Avatar
Are there any other springs that you guys recommend that Comp sells?
