do i have all the gaskets i need?
Old 02-18-2005, 05:06 PM
WS6FirebirdTA00's Avatar
Default do i have all the gaskets i need?
for head and cam install this is what i have with the part numbers. i dont know if the part numbers are all correct because i keep seeing a big variation. let me know guys, thanks
Front seal 12561244
Water pump gaskets 12559271
Front cover gasket 12574294
Oil pump o-ring 12557752
Head gaskets 12498544
let me know if i need anything else or if there is a part number change with this stuff. its for a 2000
Old 02-18-2005, 05:12 PM
JMBLOWNWS6's Avatar
Go here. http://www.ls1howto.com/index.php?article=2
- 2 GM headbolt kits (2x GMPN 12498545)
- OR ARP head bolts or head studs
- For 97-01' style heads, buy 1 pair of headgaskets (1x GMPN 12498543)
- For 02-03' style heads, buy 1 pair of headgaskets (1x GMPN 12498544)
- 2 AIR tube gaskets (2x GMPN 12553617)
- 2 Water pump gaskets for 1997-98 model cars (2x GMPN 12559271)
- 1 front engine seal (1x GMPN 12561244)
- 7 quarts of oil
- new oil filter
- Jug of dexcool compatible coolant
- RTV Hightemp silicon gasket maker
- Locktite (red tube)
- Tube of Anti-seize
- Shop rags, roll of paper towels
- One can of compressed air with plastic straw (look in computer section of an electronics store)
Old 02-18-2005, 05:17 PM
ok well i am getting afr heads but do i use the head gaskets for 97-01 i guess? i was told to get the gm mls ones, but im really not sure on what to do here. are all the other ones the same no matter what year?
Old 02-18-2005, 05:19 PM
what is the water pump gasket part number for a 2000 or is it the same too?
Old 02-18-2005, 08:01 PM
anyone else
Old 02-18-2005, 09:13 PM
P Mack's Avatar
Since you are using afr heads, you can use the mls gaskets. You only need 97-01 head gaskets if you're using 97-01 gm heads.
Old 02-18-2005, 09:39 PM
ok so i can get the 02+ gaskets then right i think thats part number with a 4 at the end
Quick Reply: do i have all the gaskets i need?
