5.3L question
Old 02-24-2005, 08:34 AM
JDM_99Z's Avatar
Question 5.3L question
i acquired some 5.3L bare heads that came off a truck, i thought about building them up to the specs of some stage 2 heads but i heard that the combustion chamber has to be grinded out to fit the LS1 cylinder size, is this true
Old 02-24-2005, 08:55 AM
TrendSetter's Avatar
They will need to be opened up if you want them to flow well. they could be bolted on as they are but you will lose quite a bit of airflow if you opt to do it that way.
