extra water temp gauge install?
Old 02-27-2005, 11:46 AM
2000ramairTA's Avatar
Default extra water temp gauge install?
i was wondering if there were any holes i could put an aftermarket water temp gauge in my 2000 ls1.
Old 02-27-2005, 01:24 PM
SiL3NtXWS6's Avatar
The sensor or the gauge itself?
Old 02-27-2005, 01:28 PM
WS6FirebirdTA00's Avatar
prob the sensor and yes, on the back of the passenger side head there is a plug. autometer has the sending unit for that. call them up and get one but get more coolant cause u will lose a lot of it
Old 02-27-2005, 07:00 PM
NHRATA01's Avatar
Get the Equus adapter kit too, none of the sending unit adapters in the autometer kit will fit that thread size.
Old 02-27-2005, 07:09 PM
none of them in the kit will work but if you call they will send you the one that does
Old 02-28-2005, 09:10 AM
Cal
Cal's Avatar
Auto Barn has the correct adapters also. Or you can do what I did: Remove the bubble tube and drill and tap that hole for the actual size you need. It's also a much easier location to get to than the one at the back of the motor.
Old 08-20-2005, 01:53 PM
JasonWW's Avatar
What the heck is a bubble tube?
Old 08-20-2005, 02:43 PM
slt200mph's Avatar
Yes what he said
Old 08-20-2005, 04:43 PM
Mr. Luos's Avatar
Through the firewall???
Where?? Drilling required?? Doing the same install myself. I need to fit some wires through. 3 gauges total.
Old 08-20-2005, 05:25 PM
JasonWW's Avatar
I'm not sure who or what your asking, but if you need to run any wires from the engine bay to the interior, use the factory hole under the ECM. All the cars wires go through there and there is plenty of room for more.
You have to undo the 2 bolts holding the wires in place, remove the ECM and you will see it. On the inside you need to remove the kickpanel. When pluging the ECM wires back you will need to place the rubber seals either on the plugs or on the ECM. One works better then the other (I can't remember which) and then push them together making sure they are getting a good seal.
Old 08-20-2005, 06:29 PM
Mr. Luos's Avatar
Sorry I was so vague. That is exactly what I meant. Thanks!!
