Comp Pro Cam Lube?
Old 02-27-2005, 05:32 PM
freakynipples69's Avatar
Default Comp Pro Cam Lube?
I saw Comp's Pro Cam Lube oil on TR's site, and it seems like a good idea to get it when I do my cam install. Is really any better then just using regular mobil 1 oil when lubing the cam for install? Here's the description.
Initial start-up is the most critical time in the life of any camshaft. Comp Cams has taken great pains to develop what we feel is the best protective break-in lubricant on the market. It must be spread genrously on all lobes of the cam, on the bottom of the lifters, and on the distributor gear when installing a cam. This is the instant protection you need to guard against any premature wear.
Is it worth getting you think or just a bunch of B.S.
Old 02-27-2005, 05:41 PM
jrp
SN95 Director
jrp's Avatar
i used it. cam was sitting in the motor for ~5 months before start up though. for just quick cam swap i'd just coat in oil.
Old 02-27-2005, 05:42 PM
Ok, thanks
