cam question....
Old 03-03-2005, 08:26 PM
theantirotor's Avatar
Default cam question....
I am considering putting a ZO6 cam in my '98 LS1. I am looking for an inexpensive upgrade and I don't need to go crazy which is why I am considering this. The engine will be installed into an RX-7 and run mostly stock. I am removing the air pump system and egr. Exhaust will be 01-02 cast manifolds, possibly ported running to dual 2 1/2 exhaust with x pipe. No cats.
I have heard that this cam can give up to 30 hp when tuned. I plan on having the car tuned after the install.
If I was to put this cam in what else would I have to change? Could I run the original LS1 valvetrain? As I said before I am on a budget with this project.
Anyone have any advice?
Old 03-03-2005, 09:08 PM
someday's Avatar
u'll hafta use LS6 springs... i'm guessing its an '02+ LS6 cam? if u want a lumpy sounding cam, get the Hot Cam instead...
Old 03-03-2005, 09:28 PM
BBADWS6's Avatar
if you are leaving the heads stock you should put in a larger reverse split cam, anything around 220-224 duration wont lope cam too hard.
BBADWS6's Avatar
if you are leaving the heads stock you should put in a larger reverse split cam, those seem to work good with stock heads. Anything around 220-224 duration wont lope cam too hard.
Old 03-03-2005, 09:44 PM
NviouSS's Avatar
there are better sleeper cams out there than the LS6 cam. i picked up 35 rwhp on stock manifolds w/my sleeper cam.
Old 03-03-2005, 10:01 PM
the key is not so much sleeper... i am looking for low cost, smooth driveability. it is going to be a rather odd sleeper as it is when an import has a v8 in it. i dont know what a reverse split cam is.
Old 03-03-2005, 10:02 PM
i was kind of hoping i could snag a cheap zo6 cam and install it using my other stock parts. i dont know a lot about engine internals though so i have been trying to read and search but there is not much out there about the zo6
i know i could buy a used one though for a little over 100. that sounds a lot more appealing to me than 3-400
am i thinking about this all wrong?
Old 03-03-2005, 10:06 PM
777's Avatar
when a cam has more intake duration than exhaust duration it is a reverse split cam...traditional is the opposite and standard is when they are both the same...
Old 03-04-2005, 01:16 AM
alright, that makes sense
Old 03-04-2005, 12:27 PM
jz06man's Avatar
The zo6 cam will be a nice increase for you, but you have to use the Z06 springs.. If you what i bit more civilized sleeper cams check out MTI Stealth and stealth 2 cam and VHP- 047 cam- 210/218 .531/.531 LSA 112.
Old 03-04-2005, 07:20 PM
Greg_E's Avatar
PM sent regarding cam.
Old 03-05-2005, 01:39 AM
prostock_bigblock's Avatar
My opinion its not worht it to go for ZO6 cam , u have many after market choices and go for ZO6 cam!!!!!
Old 03-05-2005, 03:07 AM
PREDATOR-Z's Avatar
I don't really know about you guys ut I did a little research on RX7 hybrids and they have a 3.90 rear.
A LS6 will work nice but not as much with stock heads (especialy 98). You can also get PP perimeter bolt heads Stage II for 995.00.(good deal)
With that cam and heads you can see ~400rwhp for sure.
This is from SDPC for a complete kit.
2002 LS6 Z06 Camshaft Kit, for 1999-03 LS1 Engines
Price: $574.95
Part # SD53082
Description
LS6 Z06 Camshaft Kit, for 1999-02 LS1 Engines
The SDPC LS6 Camshaft Kit makes your cam swap easy and painless. We include the GM LS6 camshaft (204/218 dur @ 0.050 and 0.550/0.550 lift), SD1423 valve spring kit with titanium retainers, Manley pushrods (7.450), Rollmaster double roller timing set plus all necessary gasket and seals and a new balancer bolt.
Note: The pushrods used in this kit are intended for use with LS1 heads only, Different length needed for LS6 heads. The block and LS1 heads must have factory deck surfaces. If the heads or blocks have been milled, the pushrods will be too long. If your heads or block have been modified, please call for assistance.
Old 03-06-2005, 04:20 AM
98A4LS1's Avatar
I thought the push rods were 7.40'" with stock LS1 heads?
Old 03-06-2005, 05:26 AM
PREDATOR-Z's Avatar
The LS6 cam has a much smaller base circle, that is why they use longer valves.
LS6 cam + LS1 heads/valves = 7.45 p-rods
LS1 cam + LS6 head/valves = 7.35 p-rods (that is what i run)
LS6 cam + LS6 head/valves = 7. 40 p-rods
Some poeple will tell you they run their LS6 cam with 7.40 p-rods, well that is why their valvetrain is out of geometry (but they do not want to admit it)
Another option is to shim the rocker stand .03 (that will get you even closer)
