crank bolt ?
Old 03-12-2005, 12:06 AM
Z06 Steve's Avatar
Default crank bolt ?
I'm doing a cam change and need to know on the 24mm crank bolt if it can be reused or should I use a new one each time.If I need a new one whats the part# ?
Old 03-12-2005, 12:09 AM
That's what she said...
TheBlurLS1's Avatar
you need to get a new one, it is a torque-to-yield unit and must be disposed of after use.
not sure the part number, but thunder racing has them listed individually as do many of the other sponsers.
Old 03-12-2005, 12:04 PM
DanZ28's Avatar
Like stated above, you need a new one. Keep the old one though, you can use it to make the first TQ pass, then put the new one in and TQ it...
Dan
Old 03-12-2005, 08:24 PM
SS SLP2's Avatar
most all dealership stock bolt, only about 5-8.00, eack time I remove pulley I change front seal, $ 5.00 ( I do not like to remove pulley just to stop leak)
just my .02
Johnny
Old 03-12-2005, 08:54 PM
SSPerformance's Avatar
just buy a ARP bolt for 22 sumtin from thunder racing that way u can always reuse it
