GM gaskets kits pt #'s 88894342 or 88894343
Old 03-15-2005, 06:20 PM
NVigR8's Avatar
Default GM gaskets kits pt #'s 88894342 or 88894343
Anybody know the exact components in these kits. Getting ready to do a head/cam swap and don't want to overlap parts.
I've seen that they include head gaskets and bolts - anything else?
Old 03-15-2005, 08:29 PM
CharlieLed's Avatar
Those are valve grind sets which usually include the head gasket, the exhaust manifold gasket, intake gaskets, valve seals, and valve cover gasket. If you are swapping the cam then you will need the front cover gasket, water pump gaskets and a new crank pulley bolt.
Quick Reply: GM gaskets kits pt #'s 88894342 or 88894343
