How much HP can stock internals handle?
Old 03-29-2005, 09:54 AM
kcfan's Avatar
Default How much HP can stock internals handle?
I've got an 2002 Z28 and I am getting a turbo and was wondering what HP limits is safe for the stock internals.
Thanks!!!!!!!
Old 03-29-2005, 09:56 AM
rtr2001ss's Avatar
I've heard up tp 600 hp on the bottom end. Don't know for sure.
Old 03-29-2005, 09:58 AM
777's Avatar
hmm it really all depends on what you do...i mean you can run race gas and get away with more...but lets just say typically you can run about 600rwhp on a stock internal, 93 octane, fuel upgrades and a tune...make SURE YOU GET A TUNE...otherwise you might not be driving it long...this is general so don't go and do it and it blow up and blame me...you may be able to run more or less..i'm just giving a guidline since there is really no set limit...
Old 03-29-2005, 10:27 AM
SSU'S Vice Mod
sb427f-car's Avatar
Tune and rod bolts, and you'll be ok for a while. But you'll eventually be a ticking time bomb with BIG power unless you go forged.
Old 03-29-2005, 01:10 PM
KB99WS6's Avatar
What about 450-500rwhp? Is the block, pistons and other internals fine at that power level? Asking b/c installing a H/C pakage that will put me at about 430rwhp and possibly might eventually add like a small 75 shot on top....
Old 03-29-2005, 01:31 PM
Wnts2Go10O's Avatar
you can put a 150 or a lil larger on it and itll take it... its the tune that counts most. investing in rods and pistons might actually not be a bad idea tho.
Old 03-29-2005, 01:45 PM
SSU'S Vice Mod
sb427f-car's Avatar
Block will be fine. Most likely, so will the internals @ that power level. I think if you push it much more than that, you'll want to upgrade, not because you have to, but to keep from junking the block in case you decide to punch a rod.
Old 03-30-2005, 03:46 PM
KB99WS6's Avatar
Thanks!
Old 03-30-2005, 04:41 PM
Camaro ChriSS's Avatar
As has been said, the rod bolts are a limit, and possibily the pistons, but likely not until over 500rwhp. But nothing is guaranteed.
Old 03-30-2005, 05:00 PM
beardWS6's Avatar
I`ve got H/C and a 150 wet shot. Car has been good for 3 years. Get it done right, fuel, tune, and parts . These LS1`s are tough for stock. I don`t spray all the time but I`ve got over 600rwhp on spray with A4. She is one mean mother! See my Sig!
Old 03-30-2005, 05:22 PM
TA BOY's Avatar
beardws6, what do u have done to ur tranny to hold that power
Old 03-30-2005, 06:13 PM
The Juggernaut's Avatar
At the flywheel I've probably made 650hp on a 150 shot (575/620 at the wheels M6)
I've made 50 passes at that level shift @ around 7k.
I have 500 passes shifting the car @ 7k on stock rod bolts.
My motor is still fine and runs strong.
The right tune helps ALOT I figure.
Old 03-30-2005, 06:17 PM
KB99WS6's Avatar
beard and 01-Z,
WOW, those are some serious testimonials that these motors are damn tough in stock form if tuned properly which IMO should be a given. thanks guys, great info.
Old 03-30-2005, 07:14 PM
goober35's Avatar
i would say anyting under 500 is safe. I have always been told that any thing over 500 is the breaking point. Not saying that it wont last i am just saying that it becomes a ticking time bomb. It is not if it will go but when.
Old 03-30-2005, 07:59 PM
equandt's Avatar
I think its an RPM thing not a HP thing.
I don't think I would take a stock bottom end over 7000 rpm. Some of these big HP guys are running pretty big cams that require them to spin the motor past 6800 rpm. The stock rod bolts just can't take the stress past that.
Stay under 6600 rpm and you can do make all the power you want on a stock bottom end with power adders or H/C set ups.
Old 03-30-2005, 08:16 PM
beardWS6's Avatar
Mine spins to 6800, and my pills for spray are 3200-6000rpms. My tranny was rebuilt by Century Trans in houston. MTI really likes them. When I go with my 408 iron and spray 250 I will go differant. I love my set-up!
Old 03-30-2005, 08:27 PM
1970judge's Avatar
about 550..
Old 03-30-2005, 08:48 PM
obrien24's Avatar
From what I have seen here locally, 650 is about the breaking point. I am planning to go 600rwhp until I have the money to build a better bottom end.
Old 03-30-2005, 11:33 PM
SMOKIN01TA's Avatar
im at 450 at the wheels now, over 500 @ the motor. i shift at 7100 and have close to 100 passes on it at that rpm and 60 passes with stock cam. still strong and i plan to add another 50-60 rwhp with heads soon.
Old 03-31-2005, 12:33 AM
04GoatBoy's Avatar
I'd agree to hangin in the 500 area and under 6800-7000. Much more and it'll just be a matter of time. You could probably beat the hell out of 450 hp and last a long time. You could get lucky with 600 for a while if the orig engine build was decent. When you start pushing high numbers then any little flaw will increase it's potential of reeking havoc. Some tight spots could be in the crank assembly or whatever, so i'd have the tolerances tightened up before moving over 500 very far. So you may as well upgrade the bottom at that time. I'd rather have complete faith by knowing what's down there than crossing my fingers.
