New Motor, How do I get oil pressure before start up?
Old 04-12-2005, 12:52 AM
racecar's Avatar
Default New Motor, How do I get oil pressure before start up?
Brand new LS6 motor in my C5. CNC heads, 11.5 compression, and a TSP 233/239 cam. I totally oiled every part in the motor when I put it together but I would like to get some oil pressure before that first start up. I have a remote filter and an oil cooler so there is a long way for the oil to travel before it develops pressure.
I could unplug the injectors, and unplug the harness to the coils and crank the motor over without any spark plugs. It would spin fast and in 10-15 seconds I would have oil pressure. Of course it will set codes with everything unplugged. I will clear the computer, plug everything in and then fire up.
Is this safe, or will it harm any electric components to be unplugged while cranking the motor?? Anybody have any other ideas for a new motor??
Thanks, I will make a sound clip of the start!!!
Old 04-12-2005, 01:05 AM
SS346Ls1's Avatar
Just unplug the coil packs, and spin it over a few times with the starter. Should be good to go?
Old 04-12-2005, 01:33 AM
pdd
pdd's Avatar
i agree
Old 04-12-2005, 01:39 AM
tbojbob's Avatar
I wouldn't spin it too long unless the fuel pump fuse was pulled also....wouldn't want to washdown those nice new cylinder walls. .02
Old 04-12-2005, 01:41 AM
goober35's Avatar
Damn you tbojbob u beat me to it. You need to pull that fuel pump fuse and unplug the coil packs.
Old 04-12-2005, 05:27 AM
Squintz Palladoris's Avatar
Damn Right
Old 04-12-2005, 10:58 AM
slow3hoe2's Avatar
works better with the spark plugs out too. and it doesnt put any pressure on the bearings before oil gets to them.
Old 04-12-2005, 07:56 PM
racecar's Avatar
Thanks guys.. this site has been the greatest tool of all for building a motor.
I appreciate your input. I will post some sound clips and motor pictures as soon as I get it to run. I'm off to the garage, a few more bolts and we will be ready to make some noise.
Old 04-12-2005, 08:03 PM
Glad we could help!
Old 04-12-2005, 08:15 PM
Wnts2Go10O's Avatar
thats why i like gen one motors, hook up an old distruibutor toa drill then spin till u get pressure w/o havin to even turn the key
Old 04-12-2005, 08:22 PM
TJ
TJ's Avatar
and you have to time the motor, adjust valves, put up with oil leaks and rtv blowing out. not to mention long ugly plug wires burning on the headers.
i think the ls series motor is better in some sense, but its got big disadvantages too.
