What size allen wrech is needed to pull out coolant drain plugs ?
Old 04-14-2005, 05:41 AM
98LS-WON's Avatar
Default What size allen wrech is needed to pull out coolant drain plugs ?
Before you say "Hey dumba$$, go measure it yourself", I'm abot 6000 miles away from my car at the moment. I want to make sure I have everything I need when I get home because I'm installing a new cam. I might as well drain the cooling system while I'm draining the radiator. I know for a fact that I don't have a large enopugh allen wrench because the last time I though about draining it I just drained the radiator because I was too lazy to go to the store at the time. Thanks for the help.
Old 04-14-2005, 07:06 AM
98TXFBODY's Avatar
Location: Used to live in South Texas, Now in North Carolina
3 of em use a 8mm and one uses a 17
Old 04-14-2005, 07:31 AM
777's Avatar
what do you need to drain the radiator...my petcok valve will not turn...is there an allen wrench for that...or is it just stuck?
Old 04-14-2005, 12:17 PM
Viper's Avatar
Sounds stuck; mine turned with a pair of pliers. How many miles on the 98'? Ever do a drain and refill? If the petcok hasn't been opened in 7 years, I imagine it might be a little sticky.
Old 04-14-2005, 12:34 PM
gojo's Avatar
It does not screw out. Dont try to do that. Turn it about a 1/4 turn so it move out of it's notch. Then, pull it outward.
Old 04-14-2005, 12:43 PM
Brains's Avatar
Then I must be crazy, because the dozens upon dozens of LS1s I've worked on over the past few years ALL had petcocks that threaded out.
Old 04-21-2005, 08:46 PM
777's Avatar
well it has 100k miles on it and i'm farily sure it was drained because the cam was installed by someone else before i bought the car a month or two ago...but it actually broke some of the plastic when i tried turning it with some pliers...
Old 04-21-2005, 09:01 PM
VSGLS1's Avatar
You are not crazy, they are threaded. No pulling involved.
Old 04-22-2005, 11:12 AM
Good Doctor's Avatar
vettes are different from F cars. One is a pull as you twist, the other is threaded.
Old 04-22-2005, 12:48 PM
gojo's Avatar
How about later model F-bodies? Just curious.
Brains, you could still be crazy.
Old 04-22-2005, 01:27 PM
Dumb Ass Vette Moderator
ls1290's Avatar
C5s use the 1/4 turn and pull valve
Keith
Old 04-22-2005, 01:37 PM
777's Avatar
and f-body's use....i'm still wondering how to be able to drain the radiator through the valve
Quick Reply: What size allen wrech is needed to pull out coolant drain plugs ?
