All pro heads, who's running them?
Old 04-21-2005, 11:42 AM
Race your car!
JL ws-6's Avatar
Default All pro heads, who's running them?
as the title says, requested some info from all pro in regards to these, and received the catalog.. looks like they can be custom cast?!? Different valve angles, all kind sof stuff. Anyone out there running a heads/cam setup and using these heads? If so, post up your results, looking for some info.
Old 04-21-2005, 12:23 PM
BTL FED's Avatar
I dont know of any cars running them yet, but check the FI section, W2W is going to do a back to back dyno between all-pro's and AFR's
Old 04-21-2005, 12:30 PM
SSU'S Vice Mod
sb427f-car's Avatar
They've already tested the AFRs and results are in the section. It's nice that Kurt is doing the work for us. JL, you raise an excellent point with the revised valve angles and that's something I'm getting ready to post up about over there right now.
Old 04-25-2005, 11:39 AM
Race your car!
JL ws-6's Avatar
Anyone have any other results on these heads? If so, what did you do with tehm as far as porting, what valve angle, all that stuff? Info people, I need info!
