waht do you think of this cam?
i can get this thunder racing cam 230/236 112 and valve springs and pushrods for 600, can i get a similar setup for around 600 that has a better cam? or is that a nice one? would any of you go wit ha different one and why? i want to make power but it is almost daily driven
i have a 2000 z28 and when the cam goes in i will have the full exhaust LT's on back, 3.42 or 3.73 gears a 2800-3200 stall "depending on cam" and the basic intake mods. do i need anything else for mods?
There are no real numbers or track times around on this cam, YET! I was looking for a cam in this range and decided to give it a shot. There are other TSP, Futral cams that are somewhat similar that put down great numbers and people on here drive them every day. I will have this cam running and tuned by next weekend.
As far as anything else you might need, the kit pretty much covers it. People on here will tell you to upgrade the timing chain and oil pump but its not absolutely necessary. Good luck!
Rob
Rob
