ECT sensor
Old 04-25-2005, 01:10 PM
1badimp's Avatar
Default ECT sensor
IM not sure if this goes here or not, but maybe someone here can help me out anyways...Anywho...while installing my longtubes, i accidently broke off my ECT sensor....From breaking that sensor off, will it make my car run like ***? Cause i noticed that my tempature guage doesnt work anymore as well...Is my motor getting Hotter than normal now?
Thank,
Paul
Old 04-25-2005, 02:05 PM
1badimp's Avatar
Come on.....not one ****** view? someones gotta know????? Help a fellow ls1 person out
Old 04-25-2005, 02:52 PM
Bad30th's Avatar
Your car will run like ***. It may even overheat since the fans don't know the coolant temp and when to turn on.
Old 04-25-2005, 02:54 PM
Bad30th's Avatar
Your car will run like ***. Temp gauge will not work, fans may not come on when they should, could overheat. Will definately run like *** regardless because PCM uses ECT for airflow etc.
Fix/replace. Unplug/unscrew old sensor, screw in new sensor and plug in wiring harness. The new sensor will come with thread sealant already on it.
Bad30th
Old 04-25-2005, 03:38 PM
1badimp's Avatar
thanks....i just got the new one on, and everything seems to run better...Hopefully that does the trick...******Note to self!!! Take out ECT before installing longtubes!!******
