pushrods same length between 5.7 and 6.0?
Old 04-28-2005, 03:44 PM
Timberwolf's Avatar
Default pushrods same length between 5.7 and 6.0?
I bought comp cams HD pushrods for my 5.7 and never used them. now with the 6.0, do I need different ones due to the difference in deck height?
Old 04-28-2005, 06:27 PM
Mr. Luos's Avatar
Interested as well.
Old 04-29-2005, 12:16 AM
Timberwolf's Avatar
heh, stumped you guys I think
Old 04-29-2005, 12:19 AM
Grimes's Avatar
I think you can use the same ones...only major difference between the 5.7 and 6.0 that I can think of are iron vs. aluminum, and a different bore. Deck heights are the same.
Old 04-29-2005, 12:22 AM
I can shift faster than you.
Jason99T/A's Avatar
All Gen III motors use the same pushrods.
Jason
Timberwolf's Avatar
well, I haven't double checked thwir info, but wiseco says the 5.7 has a 9.240 deck and the 6.0 has a 9.230 deck. I know it's only .010, so I doubt there will be a problem, but I wanted to double check.
Old 04-29-2005, 12:57 AM
PREDATOR-Z's Avatar
Most iron blocks we use are for strokers and those have been square decked and probably shaved a little.
Depending on the base circle of your cam, mill of heads, and rockers used, it is advised to use a p-rod measuring tool to really find out what size to use.
It is only $19.95 on TR site.
Old 04-29-2005, 10:48 AM
ArcticZ28's Avatar
I'm gonna be using my stock LS1 rockers and TR 7.4" hardened pushrods on my new 6.0 this weekend... I'll let you know how it comes out.
Old 04-29-2005, 11:20 AM
Derek98z's Avatar
Me too. Keep us updated!
Old 04-29-2005, 12:43 PM
87calais's Avatar
Funny thing about the Wiseco thing, I have those pistons, the Massive dish ones, sitting in a short block, And they say zero deck is 9.24 with 6.125" rods... so according to them, I should be .. oh.... .01 outta the hole right? well, they sit nicely about .002 in the hole.... So, Yeah, draw your conclusions... btw, undecked, stock stroke.
