will SvO 30lb injectors be good for a wild 382 stroker?
Old 04-29-2005, 11:26 PM
SDB
SDB's Avatar
Default will SvO 30lb injectors be good for a wild 382 stroker?
Doing big cam, heads, exhaust, intake, TB, etc. on my 382. Was running SVO 30lb Ford injectors previously. I spray WET 200 shot as well....
I plan on being about 600 crank hp with new combo (without nitrous), so maybe 500-520 rwhp (A4 with 4000 stall unlocked)...
Will I be pushing the 30 lb SVO too much or not?
SDB
Old 04-30-2005, 12:12 AM
PREDATOR-Z's Avatar
500>550rwhp can be supported (more like 500). An adjustable fuel regulator at the rail would be good. I spray dry till 550 with them (Racetronix PnP pump, harness and FR) with no problem.
However might as well do it just once and get 42 lbs injectors.
Old 04-30-2005, 07:25 AM
1BADAIR's Avatar
I will soon find out. Mine's not really wild though. 382, FFHP stage 3 heads, 24X 24X .6XX .6XX 114, LS6 /shaner S3 NX maf kit.
Old 04-30-2005, 09:16 AM
slow trap's Avatar
i'd say go ahead and go with the 42s also.30s would probably be enough for now but no one is ever satisfied so you would allready have more headroom,especially if you wanted to hit it with a dry stage also.
Old 04-30-2005, 09:31 AM
Beast96Z's Avatar
I have basically the same set-up w/ the 200 shot and Racetronix reccomended I go ahead with the 42's to keep the duty cycle low. Looks like there will be a few of us with the same set-ups pretty soon.
Old 04-30-2005, 12:44 PM
SDB
SDB's Avatar
which 42 lb are the best (easiest to tune)???
Thanks
SDB
Old 04-30-2005, 01:56 PM
PREDATOR-Z's Avatar
IMO LUCAS 42's
