How much power loss with cats?
Do you know the flow ratings of the catalytic you have listed?
What is your peak shift RPM going to be?
Just off the top, a good flowing 346 CI motor will need a minimum of 650.7 CFM
(unrestricted exhaust flow) at 6200 RPM.
That's a basic theoretical calculation using 100% V.E. at sea level.
Flow = Power
If there is a 'claim' to 54% more flow, it should open up enough air-way to
get the full potential of exhaust gas out.
Aside from pulse tuning, those cats should get you about 15-20 HP at the
crank based on the following:
I believe the stock CFM for an LS1 cat. is about 315 CFM
315 CFM * 2 = 630 CFM
If the stock cats make 325 HP @ 6000 RPM
then we can infer the following:
630 CFM / 325 HP = ~ 1.94 CFM / HP
A totally unrestricted engine will make 100% of the power at close to 650 CFM (minimum)
That would mean there is a loss of about 5% in the system
If you install the aftermarket cats:
325 HP * 5 % = about 341 HP
I know it's a crude calculation, but that will hold you over until you hit the dyno.
Please note, that's not the maximum power, but the estimated loss from
the theoretical value. 54% more exhaust flow would equal more power,
but we all know we're not going to see 54% increase from a catalytic swap!
IOW, a catalytic with 20% more flow will yield the same results all else being
equal.
equal.
