Gasket Question
Gasket Question
Alright I have a 2001 ls1 engine that i'm putting into my 91 camaro but i have a few questions about the gaskets that i hope you guys can help me with. I have new rod bolts, timing chain, and oil pump that putting in before I'm dropping the motor in, and i'm wondering what gaskets i should replace while i'm down there and which ones will be fine. Also i'm taking the intake off to get it painted so i need to know about that gasket too. Thanks a lot guys.
Justin
P.S. - the engine has 30k miles on it and has sat for about 6 months.
Justin
At a minimum I would say that you would need at least the following:
ex manif gaskets
oil pan gasket
front cover gasket
oil pump o-ring
crank pulley seal
intake manifold o-rings (these can normally be re-used - depends on their condition)
These items are not cheap from the dealer but they do sell them single or possibly in a complete re-build kit. Call your local GM dealer. Good Luck.
ex manif gaskets
oil pan gasket
front cover gasket
oil pump o-ring
crank pulley seal
SN95 Director
ex manif gaskets
oil pan gasket
front cover gasket
oil pump o-ring
crank pulley seal
ex manif gaskets
oil pan gasket
front cover gasket
oil pump o-ring
crank pulley seal
Originally Posted by jrp
front cover, o-ring, and crank seal is all i would do. the rest of the gaskets are re-usable.
The best thing would be to inspect the motor before you clean it up and see if it has been leaking anywhere already.
