Factory Bolts?
Old 05-04-2005, 09:45 AM
firefighter's Avatar
Default Factory Bolts?
So I'm just wondering in my quest to know as much as poss about the GenIII small block before I buy one to put in my Blazer X I started wondering about the bolts (heads/mains etc) what do most of you guys do buy a new set of factory bolts or just upgrade to something like ARP's?
Old 05-04-2005, 02:20 PM
sandking's Avatar
Stock head, main bolts are fine for one time use only.
Old 05-04-2005, 02:27 PM
Cal
Cal's Avatar
A lot of people use ARP's or other non-torque to yield bolts. I do.
Old 05-04-2005, 02:32 PM
cyphur's Avatar
Old 05-04-2005, 08:46 PM
So you think they are worth the $$$ I'm not scared to spend the cheddar I just don't wan't to waste it knowadimean? I'm not lookin to run 10's in the 1/4 but I'm lookin to put about 400-450 on the ground through an A4. And it'll be my daily.
Old 05-04-2005, 09:06 PM
blkZ28spt's Avatar
With the right setup you could run 10s with 450 rwhp in an A4.
Old 05-04-2005, 09:08 PM
Cal
Cal's Avatar
You're less likely to lift a head and blow the gasket in a built engine. Also, the ARP head studs preserve the threads in the block, which are shot the second time you torque normal head bolts.
Old 05-06-2005, 03:00 PM
Good to know so I'll go with the ARP's for sure heads and mains prolly every thing else too. BTW do they make a kit like they do for the old school SBC?
Old 05-06-2005, 03:01 PM
cyphur's Avatar
i would go check out ARP's website or give them a call. it wouldn't be cheap at all. ARP head bolts are ~$180 bucks alone.
Old 05-06-2005, 03:13 PM
To me that is one of those things you don't go cheap on. I've allways used their stuff on old motor builds I just wasn't sure with these new bolts.
Old 05-06-2005, 03:29 PM
cyphur's Avatar
its too bad more people don't have your point of view. i completely agree with you tho, bolts hold a motor together and shouldn't be skimped on.
Old 05-08-2005, 04:34 PM
Cal
Cal's Avatar
Yes, I got mine from Thunder Racing.
