PVC Question: T1 Cam (108 ICL), 5.7L 0.030 Milled Heads?
Sold The Fun Stuff :(
If I were running a 221/221 .558/.558 112 cam (108 ICL) on 5.7L heads that had been milled 0.030, would I be OK on PVC with 2.02 intake valves? Also, using stock thickness head gaskets, what length of pushrods would I need and is there anything else I'd need to make the geometry of the valvetrain work correct with the milled heads?
