Have Cam, Heads Are Coming, But Questions (Quench, SCR, ICL, etc)
Sold The Fun Stuff :(
MTI T1 cam is going in shortly. Heads are going to be started on next week (5.7L stock 99 castings), Stg 1.5 2.02 intake valves and stock exhaust valves. I was wanting to have the heads milled for more compression but was wanting some input...
How much should I mill the heads and what size head gasket should I run? Where does this put my quench at and how important is that?
Also, I believe the T1 is +4. Should I install it as such or install it where it doesn't have any advance?
I'm wanting the most power I can get out of this setup, but obviously I dont want PVC issues or horrible driveability. I just want to maximize this setup and this motor stuff is new to me, so any help is appreciated.
SN95 Director
milling .020 and running a cometic .045 puts you at 10.96 SCR with a .037 quench assuming a stock -.008 deck height. with a .040 cometic its 11.10 SCR with a .032 quench, again assuming stock deck height.
yes the T1 is a 112lsa and 108icl, install it straight up, meaning the 108icl.
Originally Posted by oange ss
I thought the stock deck height was -.005 ?
