205cc or 225cc?
Old 05-11-2005, 04:54 PM
1999TransamWs6's Avatar
Default 205cc or 225cc?
Currently i am running a stock bottom end and was wondering what size heads to get. should i go with the 205cc or the 225cc heads from
AFR this is a street car with a 224/228 cam. Also what compression is the most i could run? I called jeremy furnado and he said 11.5:1 on pump gas and im not doughting him but does this sound right? please respond asap because i want to buy my heads and cam already
Old 05-11-2005, 04:58 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i would run 205's, you can get the compression you want because 225 either come 72 cc chambers, or 66 milled, and that cam is the recommended cam by afr for those 205 heads
Old 05-11-2005, 05:01 PM
Ok thats what i was thinking i just wasnt too shure. So 205cc is the way im going but .....(theres always a but) will the 205cc be fine with a 383 stroker that im going to eventually put in?
Old 05-11-2005, 08:00 PM
mike c.'s Avatar
go 205's(i did)great head.if your going to a 383 with in a year then the 225's would be great,but if your like me and the ci's won't come for 3 years or so go 205's. with the right combo you'll run close to 10's on the motor with that 346(i am )and even faster on the spray.
Old 05-11-2005, 08:11 PM
That sounds good what cam are you running mike?
