Anybody running the FMS F10 cam with 342 gears?
Old 05-29-2005, 10:30 PM
ldickson's Avatar
Default Anybody running the FMS F10 cam with 342 gears?
I want to keep the 342 gear but was told that I will need to change gears with this cam.
Old 05-30-2005, 07:11 PM
98TAauto's Avatar
i dont think you HAVE to.. it would be more responsive im sure if you went to .73's or 4.xx's
I wouldnt put just 3.73's in though cause thats not a big increase to justify the cash....
im running the 3.42's with the F11 in my A4 and its very tame on the street down low.. better than I expected! FYI, i had the 224/224 .563 114 cam and this F11 cam kicks that ones azz in all around driving and performance wise! I was expecting the car to idle worse since it was a bigger cam, but it actaully idles better(more stable idle). If I did it over, i'd get the F13 on 114 for mine after seeing the F11 lol.. good luck man.. your car will be fine with the 3.42's
Old 05-30-2005, 11:15 PM
ldickson's Avatar
Thanks for the reply. Thats what I wanted to hear. How well did it do in the 1/4 mile?? did you notice any low end lost? the f11 sounds like what I want.
Old 05-31-2005, 07:35 AM
ez98ls1's Avatar
Where do you shift at with the F11?
Old 05-31-2005, 07:40 AM
blkZ28spt's Avatar
You should have no problems running 3.42's with the FM11.
Old 05-31-2005, 12:32 PM
tomaSS's Avatar
I run the F12 with 3.42's. It drives fine. You would benefit from gears but it is not a necessity. No one seems to have the F12 but it rocks. Tons of midrange, which is perfect for the street, and great top end.
