OIl on spark plug threads?
Old 05-31-2005, 04:40 PM
02WS6#519's Avatar
Default OIl on spark plug threads?
I changed the spark plugs on my car and noticed that they had oil on the threads. Why? Should I be worried?
Thanks
Ever
Old 05-31-2005, 05:04 PM
TAQuickness's Avatar
Old 05-31-2005, 06:13 PM
strokedls1's Avatar
Probably just anti sieze lube. After it's been heated cycled the plugs come out looking like oil on them. No big deal. Make sure to put some anti sieze on the new plugs.
Old 05-31-2005, 06:16 PM
StevieZ's Avatar
if your oil level goes down, top it up and don't worry where it's going. A little bit on the spark plug threads ain't no thang It's an LS1 and is still fast as stink even if it burns oil! I don't use anti-sieze and it still looks like oil! I'm still fast!
Old 05-31-2005, 07:09 PM
jermzz's Avatar
How many miles are on your car? did it have the ring placment problem? Do you burn oil? Chances are oil is slipping by the rings. When you jump on it look in the rear view for a puff of smoke.
I have 83k miles and my car had the problem and never fixed, just keep a close watch on the oil level.
Old 05-31-2005, 07:18 PM
oange ss's Avatar
LS1Tech 10 Year
or valve seals
Old 05-31-2005, 07:43 PM
02WS6#519's Avatar
Doesn't burn oil and has 30k miles.
Thanks
Ever
