T&D shaft mount rocker install questions...
just looking some basics on the install, just upgraded from Yella Terras...
what do you torque the 12pt bolts to that mount the tray to the head?
then what do you torque and/or adjust the rockers to??
thanks
I'd search, but it's broke like it seems to be 75% of the time.
thanks
I'm not sure about the 12pt bolts, but if the rockers are adjustable, you'll have to go back to the old school way of setting preload. For all cylinders, when the intake valve goes all the way down and starts to come up, set your exaust valve for the desired pre-load. Now rotate until the exaust valve cracks open, as soon as it starts to open, set the intake for the desired preload. Move to the next cylinder.
