piston ring question
Old 06-11-2005, 12:13 PM
tony124's Avatar
Default piston ring question
I am trying to figure out which is the upper and lower compression ring on a set of gm ls1 rings. one of the rings is slightly larger and has a dot which i know should face up, i'm thinking this is the top ring but not sure, i already tried a search. any help would be appreciated.
