I Have Lumina SS 2002 LS1 , I want the best cam
Hi,
I Have Lumina SS 2002 LS1 Eng.
I just have put 2 parts :
1-
Big Mouth™ Cold Air Induction
The standard system draws warm air from a small opening in the top panel and from a restrictive tube behind the bumper bar.
SS Inductions’ Big Mouth™ system channels cool air from the front of the moving car - from under the bonnet and also from the front grill area by utilising the unique SS Inductions’ aluminium air scoop which attaches to the air-conditioning condenser. This extra airflow is then rammed through the lower and front openings in the induction unit directly to the double entry intake connected to the standard airbox, ensuring maximum delivery of cold air to the motor.
Expect up to 12kW increase at the rear wheels, smoother performance, more responsive throttle and a considerable fuel saving.
The three-part kit consists of plastic induction unit, plastic double entry connecting intake and the unique SS Inductions’ aluminium air scoop.
2- Intake Pipe
The standard pipe connecting the airflow meter and throttle body is very small in diameter and has inner ridges that disrupt airflow.
The SS Inductions’ intake pipe is a three-piece high volume plastic pipe with flexible rubber ends. The increased air mass ensures improved throttle response while the inner smoothness is less disruptive to the airflow at all speeds.
from SS Inductions fotm AU.
my DynoJet run : 254HP/291T
I want to take The best cam for my Stock car.
my gear is Auto , my car in The 1st 100.000 KM
please tel me all parts I need to get the best result and nice sound
I am use my car daily please KNOW THAT
Than you very much,
www.ss2002.com
1-
2- Intake Pipe
Than you very much,
www.ss2002.com
Originally Posted by '02 SLP#686
Lumina huh... Not like the Luminas I see in the USA
Nice ride! and Good luck!
2 door is a clone of Pontiac GTO.
