what can be transfered from ls1 to 6.0 iron
7 Second Club
i found what im going to do.... finally
what parts can be transfered from the ls1 346 to a 408 iron block?
i have an 02 ls1 block....
Im going to go ahead and grab:
doulbe roller T Chain
ARP heads studs....
this is building to be a turbo motor...
any other things i need to look into?
will my 02 oil pump be good enough?
thanks,
Tyler
ARP heads studs....
thanks,
Tyler
Your oil pump should be fine. I'm not sure what else you'd like to transfer to the new 6.0 though. You're gonna need all new pistons/rods/crank due to the new bore/stroke. You could transfer the lifters if they were fine, but I'd probably recommend getting new ones b/c my next recommendation is a bigger cam. You're gonna have much better flow in the new engine to run that small of a cam. Man up and get something in the 244+/248+ region. Other than that, you can pretty much transfer everything in your mods list to the new one.
Originally Posted by Derek98z
everything transfers over. But you need to tap a third hole for the alternator bracket. I think you need to go to a LS6 pcv system, but not sure.
http://www.ls1howto.com/index.php?article=18
