Intake Valve size on a 408 (is this too big)
Help: Intake Valve size on a 408 (is this too big)
Is a 2.10 intake valve too big for a 408 (4.030 bore) I thought 2.08's were the "norm" are there any disadvantages/possible problems to having a 2.10 over a 2.08?
Thanks in advance
Thanks in advance
ok then let me also ask... whats more desirable on a 408 2.10's or a 2.08
my pistons (if im not mistaken) have a -2cc relief in them, and my intentions were to go with one of two cams: something like a 232/236 .61x/.61y lift on either a 114, or 115 lsa or MAYBE adding 2 degrees (to both sides) to the above mentioned cam. will i run into P/V problems with a 2.10 intake valve?
my pistons (if im not mistaken) have a -2cc relief in them, and my intentions were to go with something like a 232/236 .61x/.61y lift on either a 114, or 115 lsa or MAYBE adding 2 degrees (to both sides) to the above mentioned cam. will i run into P/V problems with a 2.10 intake valve?
Brandon
