Oil change after Heads, intake, LS6 PCV conv.
Old 07-07-2005, 06:32 PM
Y2K SS's Avatar
Default Oil change after Heads, intake, LS6 PCV conv.
Sup all. Currently running Mobil 1 10-30 synthetis oil in my car. Did the whole change and started her up and idled for 10 minutes. I wanna put in some regular Penzoil for like 100 miles then I'm gonna change the oil again. Is it cool to go from synthetis back to regular oil and back to synthetic again?? I heard something about gaskets before. Patman you around ??
Such a stupid questions after ripping apart an engine lol.
thanks
Old 07-08-2005, 02:22 AM
DONAIMIAN's Avatar
I dont see why not. Ive heard of road racers that use regular oil for track days, and then back to synthetic for the street.
Old 07-08-2005, 02:23 AM
SiL3NtXWS6's Avatar
I have done that many, many times on my old motor. I would use dino oil for 100 miles, and switch back to synthetic.
Old 07-08-2005, 03:17 AM
Y2K SS's Avatar
sweet. by the time you guys got to posting I already said screw it and put it in.
thanks anyways
Old 07-08-2005, 04:35 PM
ArcticZ28's Avatar
You may have problems with oil leaking from the rear main after switching back and forth between synthetic and dino oil as they have different sealing abilities. When you switch quickly to such different blends the gaskets cannot compensate quickly enough. Again, you may or may not have this problem, it's always a risk though.
Old 07-08-2005, 04:52 PM
Ryan02SS's Avatar
You'll be fine. Synthetic oil will only cause leaks in a improperly maintained engine that has been run on regular oil for overextended amounts of time. The seals and gaskets are built up with carbon, combustion byproducts and sludge. The Synthetic oil especially ester based like Redline, will slowly clean the sludge etc... from the seal and allow it to seep or leak. If your gaskets and seals are in good shape and you change your oil frequently you should have no problem.
stang killer, Using conventional oil only on track days and synthetic for the street makes no damn sense at all!!!!!!! You would want synthetic for the track.
