Which rockers do I need?
Old 07-16-2005, 11:20 PM
Moderator
xp3nd4bl3's Avatar
Default Which rockers do I need?
I just ordered a cam from Cam Motion to go with my Crane dual springs setup. I don't want to start dropping needle bearings. Which arm is considered the best for what I'm looking to do?
Cam specs are 246/257 .632/.646 113+3
Rev limit will probably be around 7400, but may vary depending on where the cam makes peak power.
Suggestions?
Old 07-16-2005, 11:30 PM
jrp
SN95 Director
jrp's Avatar
i'd look at the retro fitted stock rockers from nasty nate. i believe jason used stock rockers with his motor spinning to 7500 rpms.
or you can go all out and run some Jesel Mowaks.
Old 07-16-2005, 11:35 PM
Moderator
xp3nd4bl3's Avatar
Thanks Jerami, I read about those from Nate in your cam guide, but haven't done much research since. I'll look into it.
Old 07-17-2005, 12:24 AM
jrp
SN95 Director
jrp's Avatar
i've got jesel SS's right now, im not sure what direction i want to go; the retro fitted stock one or the Mohawks. im gonna be spinning 7k+ as well and am trying to kep reciprocating mass down.
Old 07-17-2005, 01:53 AM
MUSTANGEATER's Avatar
If you have the coin no doubt go with the Jesel's, you will never have to replace them.
OT- Jerami did you ever get your setup together?
Old 07-18-2005, 01:16 PM
Moderator
xp3nd4bl3's Avatar
Ordered some Harland Sharps per N8's recommendation.
