F11 for 6.0L
Old 07-20-2005, 12:29 AM
Deckhand's Avatar
Default F11 for 6.0L
What do you guys think of this cam for a truck application. Its a single cab, short bed, weighing 4470 lbs with driver. It does have a tci 3000 stall and 4.10 gears. I want a healthy cam coupled with a 6.0 liter , and still want to retain decent drivability. I have all boltons, longtubes, exhaust, etc.
Do you guys think that the f11 - 228"/230" .576"/.595" 114 +4 would be streetable, as it is my daily driven vehicle?
If so, which valvesprings are recommended for this application.
Thanks.
Old 07-20-2005, 08:06 AM
777's Avatar
That cam would be too small for a 6.0L IMO. I'd go with the F-13, I'd tell ya to go bigger but you might need a larger stall. I'd run the PRC dual springs.
Old 07-20-2005, 08:10 AM
ArcticZ28's Avatar
Ditto, at least F13.
Old 07-20-2005, 01:58 PM
Deckhand's Avatar
I just somthing that dosent surge, or stall out all the time. I would like to keep the 3000 converter.
Also, I will be hitting it with a 150 shot.
I would like to shift around 6500 rpms also.
Old 07-20-2005, 03:16 PM
777's Avatar
Get the F-9 (232"/236" .585"/.600" 114LSA) from futral. You will be happy.
Old 07-21-2005, 01:39 AM
Deckhand's Avatar
under the desription it says rough idle, i want somthing streetable in a heavy auto.
