early (weird numbers) cam
I have a cam (used very little) that was very early production lunati for the ´97 corvettes.
the cam has stamped:
LUNATI P84P
1449506
RRS1
218-227
99<1 114
some E-search and the comercial cam is 218-221, Im positive thta the number is a 7 (seven) compared with the other 1 (ones) the stamping has.
I writed to lunati because I do not have the card, they never even looked at my mail.... any coments about the cam; and why the diferent numbers, also someone knows someone else in lunati to send a card to my mail?
Im rebuilding a motor (Ill post a dedicated shortly)
the parts are this.
ls6 block (12561168)
almost new stock pistons, rings and rods from a 04 LS6 (teflon coated)
CNC heads (again early prod heads periferic bolts) stage III
oem ´98 head gasket
oem flat bottom intake
race bearings (no cosmetic flash plating)
stock lifter, pushrod , stock rocker, springs came with heads installed
ported, polished, AND SHIMMED oil pump
ARP in heads, bottom, rods.
ALL FREE MODS,
free flow exhaust !cats
Im aiming for 460-480 hp (380-390 RWHP)
whay do you think
greetings from Guatemala!!!!!!!
LUNATI P84P
1449506
RRS1
218-227
99<1 114
the parts are this.
oem ´98 head gasket
ALL FREE MODS,
whay do you think
