cam decision
Old 08-11-2005, 12:39 AM
Slow01TA's Avatar
Default cam decision
I'm building a 408 out of a 6.0L and I just need a few suggestions on which cam to go with. It's going to be a N/A motor running ported 6L heads and about an 11.2:1 compression ratio. I've been thinking about a 246/250 around .630-.650 lift on a 110 LSA. any suggestions would be great.This is going to be my daily driver. Thanks
Old 08-11-2005, 12:44 AM
Brandon Boomhauer's Avatar
why not a little bigger cam?
246 is fairly small for a allout N/A motor
Old 08-11-2005, 03:07 AM
DONAIMIAN's Avatar
Just go solid roller
Old 08-11-2005, 06:35 AM
Wet 1's Avatar
If you don't mind setting the lash every so often, SR is w/o a doubt the way to go for power!
Old 08-11-2005, 11:10 AM
2001CamaroGuy's Avatar
double ..........
solid roller > than all others..........
