Advice on H/C Set Up for Vette
Looking for advice (lots of heads / cam folks on this forum) on the following setup I am getting ready to install -
AFR 205 heads; Crane Cam 112 LSA, 224/224 Duration, 580/580 Lift; Crane 1.78 - 1.7 roller rocker kit; FAST LSX 90MM Intake; Shane 90MM Throttle Body; 85MM MAF; under drive pulley and blueprinted oil pump.
I have a 2001 Corvette convertible 6-speed manual 3:42 rear end with SLP long tube headers, Corsa Indy Cat Back exhaust and X pipe, "Y" K&N air snorkle. MTI dyno-tune at 334 RWHP and 337 RWTQ.
Trying to get up to around 425 RWHP and maybe 400 RWTQ while retaining street manners and driveability. This car is set up for autoX and occaissional hot *******, no serious racing.
Wanted to see if some of you hardcore H/C folks have any suggestions or other comments regarding the above before I break the car down and put it all together (I turn my own wrenches).
Thanks for your time.
LS1 Tech Administrator
If you haven't purchased the cam yet, have it ground on a 112 intake centerline. If you have it already, buy an adjustable timing set and install it at 112 intake centerline. This will allow you to make more power up high, while maintaining it down low. If the cam is ground +4, your motor will probably make peak power around 6000 rpm. No advance (112ICL) will allow it to peak closer to 6200-6300. Ideal for a 346.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
