stock flycut pistons + N20 = ?
Old 08-23-2005, 01:18 AM
JF WS6's Avatar
Default stock flycut pistons + N20 = ?
Who here is spraying on flycut pistons? If so, how deep are your cuts and what shot are you running successfully....
Just wondering. I'm planning on spraying about a 150 shot on my stock pistons notched about .090 intake .070 exhaust. I know it's risky, but I'm just wondering what others are doing or have done successfully.
Old 08-23-2005, 01:55 AM
SUX2BU's Avatar
The part of the piston that gets notched is VERY thick. your ringland will go WAY before you break thru the notch.
Old 08-23-2005, 03:07 AM
DONAIMIAN's Avatar
I agree, god forbid something happens its a good excuse to go either forged or add cubes.
Old 08-23-2005, 07:14 AM
Ben01C5's Avatar
Good to hear. I was thinking about this the other day. DOwn the road, I plan on adding a 75-100 shot.
Old 08-23-2005, 07:41 AM
necrocannibal's Avatar
Im running flycut pistons, they are notched .2 and Im spraying a 225 shot on it. I think everything will be ok.
Old 08-23-2005, 12:47 PM
pdd
pdd's Avatar
hes on a stock shortblock with stock pistons
Old 08-23-2005, 02:47 PM
JF WS6's Avatar
Yepper...... Forged pistons with valve reliefs don't count!
Old 08-23-2005, 02:49 PM
Nate_Taufer's Avatar
You'll be fine. Sardog46 used to run .080" flycut on stock pistons and he sprayed the **** out of his car turning it to 7500 rpm with the stock rod bolts. He had probably 200 passes on the way it sat.
Nate
Old 08-23-2005, 07:31 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Have run .180" Intake, .170" exhaust before on a stock shortblock w/250 shot. When it finally let go from running lean and running an agressive tune, it hurt rings/ring lands, no damage to valve relief areas.
The pistons I've measured are about .360" thick where the valve relief is located before cutting, about .250" thick in the center of the piston.
Old 08-24-2005, 10:33 AM
JF WS6's Avatar
Holy shiat! Wow that's some great information there. Thanks Joseph. I don't even think I've heard of anyone flycutting that much before, or even needing to for that matter.
You must have had a monstrous solid cam in there or something huh?
Old 08-24-2005, 07:53 PM
-Joseph-'s Avatar
Yep, had a few different test setups on that shortblock. One had LS6 heads milled .090" and a fairly huge hyd. cam setup.
You have to remember, we really didn't give a f**k about grenading a stock motor either.
If I was spraying a motor I cared about, I would do the minimum amount needed to flycut though.
Old 08-25-2005, 12:19 AM
JF WS6's Avatar
Well, I'm glad there are guys out there like you who have the means to push the limits of sanity so the rest of us know what we can get away with.....
Just out of curiosity, what kind of compression did you get out of the LS6 heads with .090 shaved off? I would have thought that much milling would fubar the flow on those, but I could be wrong. Wouldn't be the first time.
Old 08-25-2005, 01:55 AM
-Joseph-'s Avatar
It did loose airflow at peak, something like 15cfm down. I -think- the compression was at least 12.5-1, maybe a little closer to 13-1, I'd have to recalculate it if I can find my specs.
Stock shortblock motors are fun, you can thrash on them all you want and when they do finally die, your out a few hundred bucks if that to rebuild it the same. Now if we did the same thing with a forged motor, it probably wouldn't break to begin with, but if it did it hurts more since you know they cost a lot more than stock.
Old 08-25-2005, 01:57 AM
I can shift faster than you.
Jason99T/A's Avatar
