Rod bearing question
Old 08-27-2005, 08:07 AM
HumpinSS's Avatar
Default Rod bearing question
How hard is it to do rod bearings in the car. I really dont want to have to pull the motor no bearings have spun or anything just wanna freshen them up Can this be done.....
Old 09-05-2005, 06:09 PM
1badassz's Avatar
I'm working on getting main bearings out now. My next step will be to check the rod bearings. It's some what easy, just time consuming. You more or less have to drop the k-member to get the oil pan out. My current problem is trying to get the bolts from the side of the main bearings out, a regular 15mm socket won't fit.
Old 09-06-2005, 06:20 AM
roadrash9r's Avatar
if you have to drop the k member you might as well drop the motor and freshen the whole thing up. Better in the long run.. cam bearings lifters ect. how many miles?
