42lb injectors ok for 402 NA
Old 09-02-2005, 12:34 PM
Black8Banger's Avatar
Default 42lb injectors ok for 402 NA
Are 42lb injectors big enough for a 402 NA? Any suggestions on other injectors? Also I assume a 225 intank fuel pump is needed also, but are bigger fuel rails necessary?
Old 09-02-2005, 06:06 PM
mr2guru's Avatar
PLENTY big for even a 550whp NA car.
Old 09-02-2005, 07:29 PM
ArcticZ28's Avatar
Bigger rails are not necessary.
Old 09-02-2005, 07:41 PM
thanks guys!
Old 09-02-2005, 08:41 PM
Mr. Luos's Avatar
For my 402 build up I went with the Aeromotive pump and regulator, 42# injectors, and LS1speed rails. Probably a little overkill.
Old 09-03-2005, 05:16 PM
SS1875's Avatar
42#'s should be fine.
Old 09-03-2005, 11:15 PM
racecar's Avatar
I have 36# on a 346 and they run at 80% WOT at 6600. Perfect.
You should be good with 42.
Quick Reply: 42lb injectors ok for 402 NA
