36 lb injectors
Old 09-04-2005, 06:42 PM
TchargedLS1TA's Avatar
Default 36 lb injectors
How will 36 lb injectors run on a stock tuned computer.. I know not the greatest, but will it be better that the stockers in an FI situation?
Old 09-04-2005, 11:31 PM
racecar's Avatar
Way rich. I have 36 lb in a LS6 and I had to set them at 136% to get the AFR back in line. Your stock computer is at 100% it will run them 36%, too rich.
Old 09-05-2005, 12:09 AM
PREDATOR-Z's Avatar
Need to tune the pulse, I switched from 28.8 to SVO 30's (34.54@ 4 BAR). On stock tune it started, ran erratic, but once in gear they were awful.
Tune immediately after swap.
Old 09-05-2005, 01:00 AM
Dustin's Avatar
it will smoke bad and idle funny, you need a tune for pretty much any injector swap unless it is stock.
Old 09-05-2005, 07:46 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
In addition to running badly, you will run the risk of wiping out the cylinder walls due to a too rich condition. Then you're talking about a tear down, re-hone, rebuild.
I was always warned against swapping injectors without tuning it. Always tune the car prior to starting it with larger injectors.
