ATI Crankshaft Pin Kit
Originally Posted by vettenuts
Who has used this, and what speed did you run the drill for this operation? Did you use cutting oil?
I measured how deep I needed the hole to be, then marked the drill bit by wrapping electrical tape at the appropriate spot . worked like a champ!!
My Pin had to be "tapped" into place, I used a little locktite, although its not needed the balancer bolt "retains" everything in place.
Sounds like you got it done.
good luck with the rest of the install.
