Oil preasure drop
Oil preasure drop
98 TA I have the SLP oil pump, I run 40-50 as an average, but I just noticed that when the revs get up to the 5000 rpm+ range the oil preasure drops down to 25-30. I never noticed it before, but I am usually watching the tach, or the road when I am getting on it. Anyone else notice this?
Oh boy. Any strange noise from the engine? Knocking sounds? My oil pressure started doing that along with a slight knocking sound and it turned out I spun the #6 rod bearing.
Are you low on oil? It could be that too much oil is up top at high RPM's and the pump is sucking air too.
Did you guys hear ticking sound coming from the valve train? I bent a pushrod before and one of my rocker arms was oil straved. Now my motor is makeing the same sound and I think my oil pump took a dump on me after a couple hard runs. Oil purssure is lower than normal.
Oil is full and clean, no knocking noises, my valvetrain has been ticky since the H/C swap, but everyone I have spoken to said that it is normal. Car runs great, and I don't make a habit of it, but I have shifted at 6500 with no trouble just the oil preasure drops about 10 lbs. I thought about all the oil getting trapped out of the pan, but I don't really hold it at hi RPM very long, is there time to suck that much oil out of the pan?
Well after doing some more "testing" it seems to be oil getting away from the pickup somehow. If I bring the revs up slow there is no problem, when I get on it hard the car squats and then the preasure drops I added a 1/2 quart more oil and the issue got somewhat better. When I did the oil pump I did not remove the oil pan, can the pickup tube twist, or fall out of something I did not see?
Thats funny! I am having the exact same problem and have an SLP pump. When I go wot the pressure has dropped as low as 18psi. Around town during normal driving pressure is between 30-45psi. I have changed oil filters and switched to 50 weight oil and it is better but still drops.
Anybody else having this problem with an SLP pump?
Yeaps that is right, (you should for every 1000 rpms have 10psi) so you must be having a mechanical problem somewhere ie... bearings, pump or low level of oil. Also the pump pick-up screen could be blocked from dirt and other debris.
Yeah When I Did My Heads And Cam I Also Installed A Slp Oil Pump. When The Car Starts In The Morning I Had 50 Psi. Well On The Way To Work One Day I Got Into Alot Of Traffic. I Didnt Realize My Engine Had Drop Below 20 Psi So I Spunned A Bearing. People Told Me That I Must Of Had Pinch The O-ring. Well I Rebuild The Motor And Replace The O Ring. I Still Notice The Same Thing Its Happening. I Dont Know If Its A Deffective Pump Or What? So Im Just Thinking About Buying A Different Brand. Cause Im Not Blowing The Motor Again For Something So Stuppid.
Originally Posted by Z06kern
I think I am just going to buy a pump from a differnet vendor install it and see if my problem goes away.
I never noticed this before, the car sees the track maybe twice a year and has 67,000 mobil one miles on it. The o-ring seemed to go in ok, I never dropped the pan so yes the pickup could be blocked, I am not sure by what, but who ever is?
my motor has been rebuilt over a year n half. and i put slp oil pump on it, and i have oil pressure at idle 17-20 at idle, 30-35 crusing and 45-50 wot when fully warmed, and havne't had a problem yet, it has a lot of drag strip runs too. so i have a hard time to believe that anything below 40 is bad, when you put a ported pump on your gonna lose pressure because you have more volume. i have a 2000 s10 also (stock) and when it gets fully warmed it drops down to 20-25 at idle
777 what pump? I still have 45-50 at idle 50-60 till about 5000 then nosedives. Only when on it hard, it is like a pickup problem like the oil rushing away from it. I will probably drop pan, but want a pump to replace mine if nothing found. Funny thing is I was talked into this pump because 98's had problems....LOL what do I have now?
