burning more oil after heads
I put my stg II heads on back in jan. of 05. Changed my oil a couple of times since then, and everytime when I go to change I am about 2 quarts low. The motor normally burned about 1 quart between changes, but now its gotten worse. I have checked the motor and it looks like the bottom of the oil pan is lightly covered(not dripping) and when I try to trace it, it looks like its coming from the front somewhere, and then the trail just disappears. Any one have any suggestions. I will probably sit down and really take a look tomorrow when I have some time, but if anyone has advice that can save me some trouble, I appreciate it. thanks
Originally Posted by Y2K SS
Did you hook your PCV hoses back up right?? Right now thats the first thing that comes to mind.
Originally Posted by VSGLS1
Front cover to oil pan sounds like the culprit.
