about to swap in a 6.0(LQ9) + 4L65E in the silverado; quick questions
Old 09-24-2005, 02:32 PM
treyZ28's Avatar
Default about to swap in a 6.0(LQ9) + 4L65E in the silverado; quick questions
1. is a crank spacer needed?
2. is anything not interchangeable
3. the crate doesn't have power steering or AC compressor. Can i swap mine on? Alternator?
4. Can I fire it up on 4.8 tuning?
5. anything else I should know?
thanks
trey
Old 09-24-2005, 03:07 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Everything will work and is interchangeable. The only thing I dont know about is if the awd t-case and autrac t-case have the same input design but I beleive I remember someone saying they do. For future reference you can go to performancetrucks.net and oyu will probably get more repsonse the truck section broke off from tech a couple of months ago.
Old 09-24-2005, 03:12 PM
BigBlockChev572's Avatar
thanks
trey
4. Most likely it wont' fire on the 4.8 tune. Some people get lucky though. But don't expect it. Take your time too, you'll be bound to run into one problem, it's the nature of the game. Good luck!
Old 09-25-2005, 07:37 AM
treyZ28's Avatar
anyone know what I have to do about transmissions?
I have a manual t-case and a 4L65E AWD trans coming
Old 09-25-2005, 10:35 AM
6.0caddy's Avatar
I take a guy that does a lot of swaps on anything chevy, and I asked the same question. He said, to run the AWD i have to get the whole dash, cause all the wiring run through it. Takes just what He took me.
Old 09-25-2005, 11:22 AM
treyZ28's Avatar
So i am going to be bolting up my 4x4 tailshaft/t-case to the 4L65E. thanks
Quick Reply: about to swap in a 6.0(LQ9) + 4L65E in the silverado; quick questions
