Forgot sealant on rocker bolts messed up?
Hello yall i been told that i should of use sealant on the rocker bolts with ported heads on the intake side but i forgot. I drove 200miles so far with no oil lost our smoke. Should there be any problems? I really dont want to go back in there if its not gona be a problem thanks.
If there is some seepage you'll see it in the exhaust, on the tailpipes, and the rear bumper. You can pull the intake manifold and the reach in the intake port with a clean rag to see if there is indeed any seepage.
