is there a how to on changing valvesprings with heads in car?
I broke one of the valvesprings on pass side and I have an extra set but I've never done a valve spring swap. I'm afraid the valves will fall or something. I searched a few times but couldnt find a write up on this. also what are the best tools I need to buy for this project?
thanks.
Adam S.
thanks.
Adam S.
You will need a spring compressor tool $40, And a way to keep the valves from falling. TDC or compressed air. Check out the how to. You may want to do other stuff while your in there
