Rocker Arm side to side movement
Old 10-01-2005, 02:57 AM
DreamState23x's Avatar
Default Rocker Arm side to side movement
I have one valve vover off and noticed that6 of the 8 rocker arms can be wiggled side to side. not much at all but enough for them to go "click click click" when I wiggle them. I checked the torque and they are all torqed. Are they supposed to do this or should they be snug with no side to side movement?
Old 10-01-2005, 06:18 AM
vettenuts's Avatar
They will move some, especially if that particular valve is not open so the only load on them is the lifter plunger. When you say side to side movement, I assume you mean a slight wiggle not a large movement.
Old 10-01-2005, 09:39 AM
LSUxBlake's Avatar
Yeah like vettenuts said, as long as the rocker tip is still making constant contact with the valve, it's ok.
Old 10-01-2005, 11:15 AM
silverTA2002's Avatar
I noticed that too on my install. I guess it's normal.
Old 10-01-2005, 12:43 PM
Sweet. Thanks everyone.
Quick Reply: Rocker Arm side to side movement
