GTO more prone to heat soak,TR55 ot TR6?
Old 10-04-2005, 11:08 AM
JS
JS's Avatar
Default GTO more prone to heat soak,TR55 ot TR6?
I was thinking maybe the GTO could use a slightly colder plug even for NA applications being there notorious for heat soak...I'm playing around with my IAT this week as I'm trying to move it to a cooler place and insulate the CAI box alittle better as to keep the IAT's from shooting up to quickly under stop and go traffic.It drops very quickly once moving but when your driving to a light and stopped it shoots up quickly..
I thought a colder plug might help too?
Old 10-04-2005, 11:38 AM
OUTLAWZ RACING's Avatar
IM not sure if plugs will make a differance of the motor heat soaking i have been playing with the ideal of relocating the iat on a 05 but it has an zos maf i have a ls1 harness for it we will have to see if it works i will keep u updated
Old 10-04-2005, 12:55 PM
Cyborg's Avatar
JS, FYI I've called NGK and spoken to their techs a couple times over the years and they were very helpful in recommending plugs & gaps for given applications
JS
JS's Avatar
I realize temp is temp,even if u trick it its still hot but if I can get the air temp to read lower and get the box to cooler quicker by insulating it then the plugs might help.I'm not seeing heavy KR anyway 1 degree but it drops quickly as the rpm goes up..
I'm willing to bet its false KR....
Old 10-04-2005, 02:51 PM
STRIPSTAR's Avatar
its B/C the GTO is a well designed newer car and the underhood area is sealed better than the old f-bods. Beemers have the same problem and the air boxes for them are almost always isolated and insulated.
