AFR 205 vs. ET performance 215
Help me decide. I have a 99 Corvette with a Comp cam 220/224 581 114, Kooks headers, LS6 intake and stock TB. Stock LS1 heads. After waiting 4 months to save money for heads, I was always going to buy AFR. Now ET comes out and my engine builder is a dealer for them. They also sell AFR. My car is used for Autocross and Road Racing. Lot's of times, I'm very low in the RPM's coming out of corners.
I'm going to leave everthing as is, just change the heads. The ET's will cost about $500 more for the whole job. They are not CARB legal either. I live in California.
So I'm asking is it worth the extra $500? Is it even any better then AFR heads?
What do you guys think?
I'm having the heads installed Nov. 14th.
Thanks.
Steve
Thanks.
Steve
why are you in very low rpms coming out of the corner/
why not downshift?
check the dyno section, there was a recent post from a switch from afr to et heads on a small cam. Read the whole thread though, there are different variables to come into play. However I think ET's will be my head choice when money allows.
why not downshift?
LS1 Tech Administrator
While the initial results of the ET heads look very promising, you absolutely can't go wrong with the "proven" performance (especially at low and mid range) of the AFR 205s. Don't know if the ET heads are worth the extra bread or not. Time and more tests will tell.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
[QUOTE=Brandon]why are you in very low rpms coming out of the corner/
why not downshift?
In autocross it would take to much time to downshift into first then right back to second. Also some turns on big tracks you might have to shift mid- corner which is bad, so you have to go with the higher gear.
I'll check out the dyno run forum.
Thanks.
Steve
why not downshift?
Thanks.
Steve
Originally Posted by alchemistz06
ET heads outflow the AFR everywhere. You will get prolly another 20rwhp running ETP heads.
I am looking at the same thing right now. Not sure if the ET heads are available in anything but the 58 cc combustion chamber, I think they are but their web site doesn't reflect this. I really like the AFR's myself, and I too am looking for low end grunt so I will be watching the dyno curves to see how things fare.
The GMPP heads flows pretty much the same as the ET's (I have plotted all the flow data) but I don't know how they hold up for low end torque since the intake port is 244 cc.
Our heads are available in anything from a 35 - 72 cc chamber sizes. Peak numbers are nice, but it is true for what you are doing you will need low end to mid range power. A gear change can solve a whole bunch in a roadrace/ autocross application.
Our heads do outflow a 205 on the flow bench. It is a new product, thats what is great about the free world.
Facts are Facts, everyone that has run our new heads have made great power and the same with AFR heads too. Lets be real about this, there is more to come and this debate will continue for a long time.
Also, for straight bolt on is the 15 degree a better option? How does the 11 degree affect the valve train geometry if at all?
Thanks for any information, trying to get up to speed on this new product.
I believe they cnc to get the chamber, i doubt they'd mill the heads to do that.
The heads can use stock rocker arms, with the correct stand.
Oh, and post #s dont mean jack ****. i have near 6k posts, but Craig has 81. Does that mean I know more than him? I highly doubt that.
Our heads as cast are maybe 10cc if that. We CNC them which brings them up to roughly 62cc & 72cc. Getting them down to 35cc will require milling and milling to the manifold to get it to fit.
Same effort will go into the install. Things are moved in our heads, we require for a factory rocker arm to use our rocker stand. All that is left to have perfect geometry is the correct length pushrod. If anyone has anymore questions just fire away.
This is a daily driver used at the track. If you are autocrossing with aftermarket heads, you are in a modified class, where it is unlikely an LSx-based anything will be that competitive (too wide and too heavy). Similarly, the competitive road racing classes have rules that usually require stock heads (ok, maybe not ALMS).
So, the questions are two fold. First, is the CARB important or will you be able to pass with a non-CARB modificiation?
Second, is a cylinder head really the issue or would the money be better spent on shocks, springs, and tires. For oval track racing I judge every thing in terms of tires ($600/set). It is amazing how many things don't measure up. For both road racing and autocrossing a set (or multiple sets) of rebuildable mono-tube shocks. Many prefer the externally adjustable which can easily run $4-7k/set for 3-4 way adjustments. Add in tuning with different shims, pistons, and pressures, and you need to ask, is the cylinder head the next thing to change.
On the street, you probably couldn't tell the difference.
Originally Posted by SideStep
His end-all statement says it all... I am playing nice.. just a BS statement... Product just shows up and has limited exposure BUT ALL the facts and data are in... right???
If you're worried about ETP heads not performing just search around on google for their other non Gen III heads. People act like ET Performance just showed up a few months ago and said okay we are the shizz. Theyve been around for quite a while. Hell W2W loves ETP because of proven gains switching from ported ls6 heads to the ETP ported 5.7L heads.
Nate
Guys...
I posted this paragragh or two in another thread concerning the latest AFR debate but thought it was worth sharing here as well for those who might have missed it.
"The initial results from a few ET head installs certainly look promising. There CNC work looks very good (on par with our own quality) and lets not forget they have the advantage of a much shallower valve angle and a raised exhaust port which always enhances airflow and ultimately power output. Is the ET 215 really worth a significant power advantage over an AFR 205 nine times out of ten??....Anybody's guess and the bottom line is we will have to wait and see as more results make it to this website and others. I take my hat off to ET as the product certainly looks good and the results promising, but I think we need to see more of both to determine what the gains (or losses) will stack up to over the long haul. I would still choose a 205 for a street/strip car that wanted to place an emphasis on the "street side" of that equation, as the smaller port is still going to get the nod for part throttle and fuel economy, and we all know the proven power potential even with smaller cams and the right AFR 205 set-up.
Don't forget that AFR set their sites on building an emissions legal direct replacement performance head (all geometry exactly like stock), and within those parameters we have certainly hit a homerun. Are we sitting on our hands now that project is almost complete (awaiting the release of the small chamber 225)?? I will leave that to your imagination...Don't throw away all your "blue pills" just yet....
Competition is a good thing and technology marches on....Exciting times for sure."
Also, as Craig previously mentioned....I'm sure this comparison will rage on for quite some time as more and more ET combinations find their way to these pages (as well as additional AFR headed engines as well). With a larger cross section of information to evaluate, it should be alot easier to approximate or guess how they fare when compared to AFR's current offerings.
There has never been a better time to be an SBC enthusiast (Ford and Mopar fans aren't doing to bad either)...Let's all enjoy it before the government has everyone driving electric cars while the rest of us drive our Hot-Rods like "Mad Max" following fuel tankers thru the desert
Regards to all,
Tony M.
Regards to all,
Tony M.
Regards to all,
Tony M.
Regards to all,
Tony M.
My car in autocross is already in the modified class (SM2) and the Corvettes usually win. In fact I don't think one has lost yet that I have seen. When I go to Willow Springs in California it's just for fun. No times, just running around on the track with 20 other drivers. I'm a instructor too. This is the last thing on my list of mods. Suspension,Alignment, Coolers, Wider wheels, tires all done. Your right when it comes time to spend money on mods, I first think about tires I have to buy every 3 months, rotors, brake pads, ect.
Thanks for the comments.
Looks like I'm going with AFR.
When it gets done, I'll post the results. Should be in 2 weeks.
Steve
[IMG][/IMG]
