Modified oil pan - need advice
Old 11-17-2005, 03:07 PM
55chevy's Avatar
Default Modified oil pan - need advice
I'm putting a LS1 in my '55 and the only way I could keep my original type steering was to get a modified oil pan and pickup tube from Street and Performance. Now I'm getting worried about losing approximately 1 quart of oil capacity with the modified pan. I'm putting stgII heads, 224 cam, and headers on the motor and plan on taking it to the track a few times to see what it will do.
What options do I have to ensure I plenty of oil flowing in the motor?
Thanks,
Steve
Old 11-17-2005, 03:29 PM
oange ss's Avatar
LS1Tech 10 Year
i wouldnt worry about it
Old 11-18-2005, 08:58 AM
55chevy's Avatar
Does anyone else have any input? I do plan on adding a larger capacity filter and a APE p&p oil pump. Do I need an external oil cooler or anthing else? Thanks.
Old 11-21-2005, 11:24 AM
samgm2's Avatar
Have you tried other oil pan options?
The truck oil pan for instance has a HUGE capacity and may work better for your application. This truck pan is on tahos, etc. It fits the 5.3L and the 4.8L LSx type engines. Basically a bit smaller displacment and an iron motor.
I installed an LS6 in my Miata and used the truck pan after cutting it shorter for ground clearance. The welding was relatively easy and even after shortening the pan quite a bit, I am able to hold 6.5-7 quarts with no problems.
You can also use an external oil reservoir. I forget who they're made by, but in essense, they allow you to store oil when there is pressure (works against a piston) and release it when there is not. Great system and adds additional benefits that you don't normally have when going around a corner for example.
Sam
Old 11-21-2005, 11:56 AM
TAF Motorsports's Avatar
Put in a accusump system ,
http://www.accusump.com/
Moroso makes one too
http://www.moroso.com/catalog/catego...?catcode=13600
Old 11-23-2005, 03:58 PM
55chevy's Avatar
Thanks for the info. I'll look into these options.
